d_daffron
1985 Monte Carlo SS for sale
Engine
396" SBC
Eagle Forged 3.875" stroke crank
Scat Forged 6" I beam rods
Probe Forged pistons
880 4bolt main block bored 4.040"
Lunati custom grind Hydraulic roller cam about 230* at .050 (I have the cam card somewhere)
Holley Sniper EFI system
Victor Jr CNC intake
AFR 210cc heads
Hooker Super Comp headers (the ones that don't have a tube that wraps around outside the frame rail)
Vortec Serpentine belt setup
Transmission
Mcleod dual disc RST clutch
Ram billet flywheel
RAM internal mount Hydraulic throwout bearing
Camaro T56 6 speed trans
Sonnax forged slip yoke
Rear axle
Moser ford 9" with their custom housing ends that bolt to Camaro rear disc brakes
31spline Moser cromoly shafts
4.10 gears
Ford limited slip carrier rebuilt with an extra clutch in the pack to make it hold tighter
Torque arm rear suspension with watts link
Afco racing link bars with 3/4" rod ends, there are no rubber bushings in the rear supension
Front suspension
Global west tubular b body swap upper control arms
B body spindles
12" disc brakes, camaro 1LE rotors
Other stuff
Hydraboost brakes so the cam doesnt affect brake power
Body was pulled off the frame and the rails were boxed
All body mounts replaced with aluminum pucks
VDO speedo and tach in stock gauge cluster
1987 rear bumper and tail lights because they look better
GM replacement front nose because old one was saggy
Bad stuff
Driver seat has a small tear
Dash has some cracks on top
Located in Tuscaloosa AL
$13,000 asking price
Engine
396" SBC
AFR 210cc heads
Transmission
Ram billet flywheel
Rear axle
4.10 gears
Front suspension
B body spindles
Other stuff
Bad stuff
