1997 Jeep TJ crawler
Cjcooper92
Member
Title in hand
Front axle - Dana 44, trussed, disc brakes, 3 link with track bar, 1.5" stretch, 4.88 gears, ARB air locker, RCV 30spline shafts, warn premium locking hubs, also have RPM heavy duty lock out pucks. HD steering with heims and DOM tubing, PSC hydraulic assist ram, coil springs, 14" bilstein shocks, Currie anti rock sway bar
Rear axle - Ford Explorer 8.8, disc brakes, 31spline shafts, 4.88 gears, locked, 4 link, 10" stretch, 14" Fox 2.0 coilovers
New 38" TSLs on 15"x 10" wheels, trail ready aluminum bead locks
Frame - RUST FREE, custom high clearance back half kit. Custom front and rear bumpers,
9000lb winch
Aluminum 15 gal. fuel cell
3/16 steel boat sides
1/4" custom aluminum rear armor
1/4" aluminum tailgate
Body is nearly damage free.
Bmw retrofit front seats, factory bench rear
Harness bar, 4pt harness front seats
Bed lined floor
Custom hood vents
Custom dash driver & passenger sides With 7" screen, custom center console
Battery relocated to center console, huge deep cycle, 450 amp main disconnect
Headlights and tail lights work, good windshield, wipers work, heater works
Memphis Amped sound system
NOW FOR THE FUN PART
2002 5.3 LS
Summit stage 2 cam
Cam motion 1 piece pushrods
Brian tooly racing dual platinum valve springs
egr deleted, LSX innovations block off plates
LSX innovations knock sensor delete plate
Stainless steel headers
Custom 2.5" full stainless exhaust with stainless resonator
Built 4l60e with 2600 stall converter
Np241c driver drop Tcase
Aluminum radiator with electric fan
Comes with 2 custom street tuned ECMs
1 is tuned to the max for every day use
1 has the timing retarded for nitrous
OH YEA, it has a 100hp wet shot of nitrous
ZEX nitrous kit runs with a wide open throttle switch and a rpm window switch. Paired with the nitrous ecm this is the safest way to spray nitrous.
I've only sprayed it once on the street, and yes it made a HUGE difference.
I think it's worth every bit of 15K
But if your serious, we can negotiate.
The trailer goes with the sell
TJ with a LS and a 100 shot of NOS is not something you see everyday.
Always liked the concept of the minimalist trailer and that one looks pretty cool.
