Sold/Expired 2 Dana 60 hybrid axles
Lickliter21
Lawrencburg Ky
Rear is a Dana 80 with 4.10 gears welded carrier.
superduty outers 30 spline with 170mm to 8x6.5 wheel adapter spacer
Seals from jegs
Inner shafts from superduty splined by moser
One broken stub shaft. one good stub shaft
Steering cylinder from tractor supply 8" stroke
Front is a driver drop 14 bolt no gears or carrier
Inner shafts 30 spline 14 bolt done by moser.
Seals from jegs
also has broken stub shaft one good stub shaft
wheel adapters
Both axles complete minus the broken stubs and 14 bolt gears
rotors caliper and unit bearings in the building
Changed axle because they couldn't take 44 tractor tires.
1000 make offer
Located in Lawrenceburg Ky 40342
Call or text (502)352-0996
