l.c.crwler
- Joined
- Oct 4, 2010
- Messages
- 55
MUST SALE JUST GOT LAID OFF WORK THIS MORNING 3/11/11 $15000.00
Frame:
Custom tube frame made from 1.75 HREW.
14ga body panels and floor boards
Full fire wall
Heavy 4-link tabs upper and lower
Suspension:
2.5" Fox shocks on all corners.
Rock Equipment Anti-sway bars front and rear.
4-link front and rear with heavy links
1 1/4" Heims on all link bars
Ballistic 4" bump stops on front
Poly Performance limit straps front and rear
Engine:
350 Chevy
Flat top pistons
Roller Rockers
Small Cam
Shaved 305 heads
Impco Propane set up
Aluminum Radiator with Electric fan
Headers
Drivetrain:
Turbo 350 with cooler and dedicated fan
2200 TCI Stall
203/205 Doubler
203 has all Ford components
Art Carr Shifter
Northwest Fab Triple Stick Cable Shifter.
1410 Yokes on both outputs
Driveshaft Superstore front and rear driveshafts
Front driveshaft is two piece with pillow block bearing
Axles:
2.5 Ton Rockwells
6.71:1 gearing
welded front and rear
MudProMetal Pinion brake brackets and rotors.
Toyota calipers
Front has all new bearings and axle u-joints
Tires:
mrw beadlocks with 44 tsl one ride
Other items and specs:
127" Wheel base
22" Under Belly
71" Overall height
Corbeau Ultra SS wide seats
PSC pump, orbital, cooler and tank
TSC cylinder
4-point harnesses
Tach, Temp, Oil Pressure and Amp gauges
In cab winch control
the bad
motor has bottom end rattle when warm maybe crank kit or just bearings don't know
needs front brake line
right front wheel was beent from rock but has been straightened out
i love this buggy don't want to let it go but realy don't have the money to fix it or a place to keep it. price is firm $17000.00 name is patrick and # is 770-468-6423 located in barnesville ga 30204 bout 50 or so miles south atl
http://s563.photobucket.com/albums/ss74/prochester/buggy/
Frame:
Full fire wall
Suspension:
Engine:
350 Chevy
Flat top pistons
Roller Rockers
Small Cam
Shaved 305 heads
Headers
Drivetrain:
2200 TCI Stall
203/205 Doubler
Art Carr Shifter
Axles:
2.5 Ton Rockwells
6.71:1 gearing
Toyota calipers
Tires:
127" Wheel base
22" Under Belly
71" Overall height
TSC cylinder
4-point harnesses
the bad
