Pineygroveoffroad
(SOLD) 2016 Elderfab Rock Bouncer
LQ9 6.0 Lsx engine
Gm performance hot cam/valve springs
Fast xmi ignition controller
FiTech fuel injection
Custom longtube headers
3" exhaust
Thrush mufflers
C4 transmission
Jw bell housing
3500-3800 converter
Trans cooler w/fan on thermostat
Winters sidewinder shifter
Atlas 4.3 transfer case
Dana 60 high pinion front axle
Detroit locker
35 spline Ten Factory inner/outer chromo shafts
Longfield axle joints
Solid drive flanges
Solid diff cover
4.10 gear
Custom aluminum high steer arms dbl shear
PSC dual ram cylinder/ reservoir
Wilwood brake calipers
14" Fox emulsion coilovers/ Eibach springs
Fox air bumps
4 link 3/4 heims on top links, 7/8 on bottom
115" wheelbase
Weight is 3750 lb
Frame is powder coated
14 bolt rear axle
Detroit locker
Yukon axle shafts
4.10 gears
Solid diff cover
14" fox emulsion coilovers/ Eibach springs
Currie anti-rock bar
Kirkey pro street 17" seats black vinyl covers
Gforce 5 point 3" latch/link harness
Dual pass aluminum radiator w/ electric fans
9500lb Runva winch
Single row led lightbar on front
43" TSL Sx sticky front tires/on
17" aluminum Raceline beadlock wheels
18.4/16.1 Firestone tractor tires on rear/on
Steel diy beadlock wheels
Located in Somerset Ky
$35,000 obo
Call/text Matt Elder 6062717482
LQ9 6.0 Lsx engine
3" exhaust
Thrush mufflers
C4 transmission
Jw bell housing
3500-3800 converter
Detroit locker
Solid drive flanges
Solid diff cover
4.10 gear
Fox air bumps
115" wheelbase
Weight is 3750 lb
14 bolt rear axle
Detroit locker
Yukon axle shafts
4.10 gears
Solid diff cover
9500lb Runva winch
$35,000 obo
