4 seater buggy. Originally built as a 2-seater by me in 2010 then underwent a major rebuild around 2015-17 by MarsFab and made a lot of improvements for comfort, safety, performance, and add the rear bench seat. I just don't use it as lifestyle and family grows. It might have 100 miles on it after the last rebuild, including the engine Haven't even used it enough to even put the skid plate on. Working on building a house and the space and $ would be helpful.
engine specs:
2001 LS1
-Block hot tanked, inspected, bored .010 over
-Heads hot tanked, inspected, valve job done, new valve seals, springs tested, new locks and retainers
-Crankshaft hot tanked, inspected, polished standard
Upgraded engine Parts:
-Mahle .010" Over Hypereutectic pistons
-Hastings Moly Rings
-Clevit P Series Main rods and bearings
-Durabond Cam bearings
-GM Performance Parts MLS gaskets
-New GM head bolts
-Victor Reinz gasket and seals thoughout
-Melling Oil Pump Pickup
-Melling M select 10296 performance oil pump
-New GM LS2 timing chain
Holley drive by cable throttle body. I think it's a 90mm, maybe 92mm
Upgraded injectors and fuel rails
TBSS intake manifold
F body oil pan with improved racing baffle
2qt oil accumulator
transmission: rebuilt th350 with derale trans cooler.
Transfer case: atlas with 1350 front output and 1410 rear, 3.8 gears (90% sure), cable shifters
d60 front with zip locker, 5.38 gears, Solid outer knuckles and steering arms. ECGS drive flanges, Nitro axles and joints
14 bolt rear, 5.38 gears, spool. Spidertrax brake hats and rotor with 4 piston calipers
43" SX sticky tires, no holes and very little wear.
17" Raceline monster beadlocks powder coated black and gold steel outer rings. Hardly any flaws or rock rash.
18" ORI struts
Trophy truck steering pump with custom tank and dual ended ram
Corbeau suspension seats and rear bench seat, all with heated seats
Corbeau harnesses front and rear
LED light bars and headlights, Rock lights, back up lights, and interior lights
Hella horn
Turn signals
Lowrance HDS GPS
Rugged Radios 4 person intercom system with 50W radio
Wiring by Mars Fab using weatherproof connectors
Cup holders and even a custom square one if you like to drink Fiji water. It might fit a bottle of Jack.
Onboard air
Dash heater
Warn 9.5 winch with synthetic rope
Warn works rear suck down winch
16 gallon fuel cell out back
Spare parts basket in the rear
Mounts built into the chassis specifically for a Yeti cooler.
$37,500, located in Greenville, NC
I'd consider trades for a good, mostly stock 4-seater UTV, kubota l2501 tractor, or even an older camaro in decent shape.
can send me a message but I don't get on here much. May be easier to call/text. 252-341-twozeroonesix
engine specs:
2001 LS1
-New GM head bolts
2qt oil accumulator
18" ORI struts
Hella horn
Turn signals
Lowrance HDS GPS
Onboard air
Dash heater
