Sold/Expired 4 seater buggy with 6.0 and tons. ******SOLD*******
jeff150
Hazel Green, AL
Posting for friend. Lots of good parts in this buggy as it was originally built as a dual purpose Ultra 4 and trail riding buggy. It rides and handles great whether going fast or bouncing up the rocks. Hulk wrap was put on for his daughter who is a huge fan but it is removable. Rear seat is tight but doable for two adults. works well for kids.
Asking price is $24,000 Call or text Shane @ 256-503-3179 Buggy located in Hazel Green, AL
Specs:
6.0 Chevy from a 2006 Silverado (LQ4) 89000 miles
Computer tuned by LT1swap.com
4l80E 2-wheel drive trans out of the same 2006 Chevy
Winters cable shifter
205 divorced transfer case
1410 U-Joints in the driveshafts
Chevy D60 Front Yukon 4340 Shafts 4.10 gears
35 spline outers
14b FF rear 4.10 gears Disc Brake swap
Ruffstuff pinion guard
Ruffstuff diff covers
Trail gear double ended ram
Trail Gear orbital
PSC wheel with quick disconnect
PSC column
Artec front truss and ram mount
Artec steering arms, connect to the factory arms for a stronger knuckle
ARP studs for the arms
Ruffstuff ¾ x7/8 steering heims
RPM off road heavy duty 35 spline drive flanges
Like new 42" TSLs on recentered H1 beadlocks
Chassis built by M4 fab 1.75"x.120"
2x2x.250" Subframe
3/8" ruffstuff tabs at axles and frame
E2000 fuel pump, with spare
Double triangulated 4-links front and rear
Profender 2" remote res coilovers for coil carriers in front (no valving)
Profender 2.5" triple bypass shocks in front
Profender 3" travel 2.0 bump stops in front
Profender 2.5" Coilovers in rear
Corbeau Baja SS front
Corbeau Baja Bench rear seat 42"
Derale Trans cooler with 10" fan
Oil and Power steering coolers
Dual pass aluminum radiator
Autometer Phantom 2-5/8" gauges (water temp, trans temp, oil pressure)
Eagle 500C GPS
22 Gallon Summit fuel cell, Steel with plastic bladder
Remote fuel fill
Amber, red and blue lights, including brake light
PRP 5- point harnesses in front
PRP 4- points in the rear (seat belt style so the kids can buckle themselves in)
Custom window nets
Engo 9000lbs winch with Synthetic line
10" LED flood pattern light bar
115" wheelbase, 18" belly clearance, 76" overall height
Re: 4 seater buggy with 6.0 and tons
pictures
pictures
awsome buggy!! have rode with it since i started ridding and even rode in it quite a bit!! very dependable and flat out works :****: :dblthumb:
Bump for the most reliable rig in our group. :****:
You can own it. :****:
Give Shane a call to set up a test drive...
Is this buggy sittin on left at a body shop on left side of 231headed north in hazel green
Yes. He has that one and another one that sits outside his body shop.
Liked the other one too... Recon he'd sell it? Think it was black..& full tube buggy with few panels... Saw it few months back coming thru there... :fish:
He might but I doubt it. It's silver now and he's racing srrs with it.
Unless I wanted a dedicated hill killer, I'd take his hulk buggy over the silver one. Great reliability and really nice suspension setup for multipurpose use.
bump for a awesome rig and a awesome guy!!
This is a great buggy. Love it.
Thanks. It is a good rig, just doesn't get ridden much since he bought his other buggy and a GMC Jimmy to take the family wheeling.
Re: 4 seater buggy with 6.0 and tons. Price drop to $24,000
Motivated seller. Too nice a rig to just sit in the shop.
Coming to Hawk Pride Saturday. Will probably put this on the trailer also if anyone wants to check it out in person.
