its a switch. The side of the tranny needs 12v. You take 12v from the battery or fuse block, run it to one side of the switch, then the other pin of the swithc to the tranny. make it so the switch is activated when you depress the throttle past 3/4 or so, so it stays downshifted at full throttle. That and unhook or put a ball valve on the modulator vac line. That helps. Tranny thinks engine is wot all the time.
