89 Samuria out of control
Binmon
Member
Hamilton,AL
I Just bought an 89 Samuria, It is 3 link in front, 4 link in Back.. Has 35 Super swamper tires.. I cant get above 25mph, its totally out of control how can i stablize it?? Sway bars maybe?? Any advice will be greatly appreactiated, Thanks
Re: Re: 89 Samuria out of control
Sway bars.
Air shocks? Coil springs? Im sure the link geometry has somethjng ti do with it.
But if you want a dd/ trail rig stick with leaf springs.
Sent from my DROID RAZR using Tapatalk 2
thats getting pretty tall for 80in wheel base.that will have a little to do with it.
Sent from my DROIDX using Tapatalk 2
Shocks, Where could i find Leaf Springs?? and still be high enough to run 35s ??Im not Intending on driving everyday, But Would like some control on highway.. Would sway bars have some better control?? [30TH6} So are you saying wheel spacers may be a thought??
Not enough pics can be alot of things out of balance tires , bent wheel, steering geometry, link geometry ad wheel bearing, bad king pin bearing too many things for just one pic
I bet the front end has been rotated up for better pinion angle and has the caster way off! been there and done that! you cant hold that bitch between the ditches at any speed
p
I'm betting this! And something that short and tall is going to drive awful.
100 % right
set up way off
That's what they mean.
It would help to post another picture to show what the front looks like. It's likely that it has been turned at one point but not 100% without seeing more detailed pictures.
Has it been aligned? Tires balanced? I know these likely aren't as big of a problem as the pinion angle but it may help some.
I can't tell from the pic but if the pinion has been rotated up it will dart all over the road like others have stated. Think about it like this. Take a wheel barrow, they steer fine when your arms are strait by your hips. Raise you arms up to your chest and steer it. It will dart all over. This is what happens to the steering knuckles when you rotate the pinion up to keep the ujoints in the front driveshaft happy. I have had good luck with about 7 degrees caster.
Okay The local Community College is gonna take a look at it, I told the instructor that 7 degree is about where it needed to be.. But one more question would the lift have an effect?? Even if i set the caster at 7 degree?
Heres a pic, what yaw think? sorry its the best i could get
