Turn key rig that requires very little maintenance. Technical crawls and hill shoots very well.
Originally 2wd 94 tacoma with title
2rz with balance shaft delete and tune
W56 transmission
AA billet crawl box to 4.7 gearset in the rear case with marlin competition chromo gears and 30 spline output & twin stick
ARBs front and rear Dana 60s w/5.86
300m 35 spline RCVs and Reid knuckles
35 spline rear chromo Yukon shafts
8.75" psc ram/resi
Aluminum links upper and lower
14" fox coilovers tuned and freshly rebuilt
4" Fox air bumps
Onboard air and tank
Jaz poly fuel cell
Derale pwm fan controller
Rear Jamar cutting brakes
Rear line lock
Newer 43" stickies on ATX chamber 2 beadlocks
XRC winch and synthetic line
Ammo boxes and fluid carrier
Rock Lights
Small stereo and power inverter
Optima battery
K&n filter
Heat still works
New clutch Hydraulic system
Fresh redline transmission fluid
Full size 42" PBR on ATX chamber II wheel as spare
114" WB and 21-23" belly I believe
Located in Lincoln, Nebraska
$18500 obo
W56 transmission
8.75" psc ram/resi
4" Fox air bumps
Jaz poly fuel cell
Rear line lock
Rock Lights
Optima battery
K&n filter
Heat still works
$18500 obo
