TacomaJD
I LIKE CHEAP STUFF.....
Re: Re: Air Conditioner...Rheem vs Trane vs ????
All electric heat pump. So when I'm looking online, am I seeing correctly that a new 1.5 ton Rheem split central unit (condenser and air handler) can be had for around $1600? If all my current duct work is still good and all that has to be switched is the condenser, line set, and air handler, what kind of total charges should I expect to see from someone including material and labor? Or is there more to it than just switching those things? Would like to know ballpark figure on what to expect when calling to get quotes on total install.NOVI FED COUPE said:I think that small of a house a 1 1/2 ton is fine. Either way you go with a Rheem the indoor part of the system will be a 2 ton...just the outdoor section will be 1 1/2. Is it gas or heat pump?
