Sold/Expired BRACKETS, TABS, TRUSSES, WELD ON BEADLOCKS,
Beyondprecise
www.Beyondprecise.com
1/4 rock rings
3/8 flat centers
8 12 24 bolt
WE WILL WORK WITH YOU ON OUR CUSTOM BRACKET DESIGNS THROUGH SOLID MODELING
USING SOILD WORKS
Many designs available
All wheel patterns
Re: H1 beadlock rock rings and flat centers
Design
Rockwell flat center
Rockring design
Design
We make kingpin style chevy and dodge
Dana 60 trusses also
3/8 top plate
14 bolt pinion guards
50 dollars include shipping and hardware
3/8 1080 steel
Cnc bent and cut
Rockwell bump stops
Or spring pads
We have several rockwell link brackets
Kits, top hat, pinion brake set up
Custom 20 inch rock ring
keep it up. y'all are doing good. saw those rims on face space the other day didn't know y'all made them. Hope to be ordering some Rockwell stuff from y'all soon! :dblthumb:
Some recent Weld on bead locks we designed and built
15" .250 starting at 175.00 a set plus shipping
Rockwell top hats 135.00 shipped
hardware and top link tabs included
14 bolt full truss
3/8 top plate
3/8 pinion guard
1/4 bridge
includes all link and coilover shock mounts
Re: Trusses pinion guards 2.5 rockwell top hats rock rings and flat center beadlocks
couple of new rockring designs
I can't say enough good about this company called them up to see if they had a bracket that I was looking for and they ended up making one exactly how I wanted it and was cheaper than the big guys also fast response and shipping check them out these brackets are 3/8 flush mount lower 4 link mounts
