Sold/Expired Buggy 2 Seater 4 wheel Steer
MJP
Ram Jet 350 Small Block Chevy
Fuel Injected
New Fuel Pump
Fuel Cell
200 AMP Power Master Alternator
PSC Steering
Orbital
Pump
Rams Double Ended
Rear Steer is controlled by an Electronic solenoid pack
Transmission
Th350
Manual valve body
Compression braking
Art-Carr Shifter
Dana 300 with Cable Shifters
LowMax 4:1 kit
32 Spline outputs from advanced adaptor
1410 yokes
AXLES
Front
Chevy 60 front 5.86 gears
High Steer with PSC Double ended ram
Aluminum Tie Rods 2in
RCV Performance CV rear shafts, RCV Drive Flanges
Locker
3/8 diff cover with counter sunk allens
1410 yoke
3/8 enclosed tabs
.188 wall DOM Double Truss
Rear Steer 60 5.86 gears
Locker
1410 yoke
3/8 enclosed tabs
1410 ujoints from front to back
Aluminum Links
3/8 tabs frame/axles
Full 5/16 Skid from front to back. Skid starts in front of the 14in
Fox coilovers with the triple rate kit
Corbeau Baja Ultra Wide Version
Crow Padded Harnesses
40 LTB's TN Cut
Inner AIR LOCKS Beadlocks
Rear mounted Radiator with dual fans
Wilwood brake pedal setup
Dual Master Cylinders, one for the Front and one for the Rear
Stainless steel brake lines
Quick Release Steering Wheel
Built in Cup holders in the center console
I built this buggy a couple years ago and have really enjoyed it. I didnt think I would ever concider getting rid of it but since the kids have gotten older I find my spare time is less than it was.
I recently cut the rear of the tube work off to make it into a 4 seater. It can easily be finished into a 4 seater or put back to a 2 seater.
A weekend of work you would be ready to hit the trails.
Thanks
Mike
232323232%7Ffp63246%3Enu%3D3355%3E37%3A%3E4%3B8%3EWSNRCG%3D337%3A%3C34684337nu0mrj
please send pics and specs to [email protected] or text them to 9317976676
Re: Re: WTT Buggy for a Tractor
TBItoy said:
Didn't you originally have propane on this buggy or did I make that up?
yes, it had propane on it. i upgraded to a fuel injected RamJet 350 crate motor
Here are some pics of how it sit now.
Re: WTT Buggy for a Tractor (Now has current Pics)
:eek: :eek: :eek: Built in Cup holders in the center console :eek: :eek: :eek: you can not hide money :****:
how much without engine and trans?
$13,500 minus Engine, Trans, And Tcase
Would you be willing to sell only the chassis?
chassis
links
link heims
engine cage
skid (belly and engine)
motor mounts and tranny mid mount
petal mount
orbital mount
seat and harness mounts
built in console
all chassis 4link mounts
front coilover mounts
original back i cut off
2 stick of DOM to finish out the chassis
$4500
How much for the axles front and rear I have two steering rocks in my smith buggy and wanting to go to something lighter
hey bro if youwant to trade down on another perfect buggy pls call me i want a buggy i have cash to throw your way i want to rock bounce harder. and your rig would be a great start for me 6788581219
I found a tractor.
What else do you have that I cant live with out?
Interested in a 32ft. gooseneck for the chassis and accessories you have listed with it?
8ft wide
dual tandem
2-10,000 lb axles
good tires
all lights
around 41ft overall length Needs brake wire ran and pads.
Front spring hangers need attention, showing some wear.
decking in good shape
8ft wide
dual tandem
2-10,000 lb axles
good tires
all lights
if you want to discuss a possible trade feel free to give me a call
931-797-6676
