Sold/Expired Cj yj tj xj zj parts and some builder parts...Greensboro NC
Spraypaintman
I also have two xj's to part out an 87 and a 99 and a 72 jeep commando and a 76 cj5 to part out! Let me know what you might need!
Upgrade your 4x4 with these parts!
Dana 44 rear axle out of the same vehicle with quadratrac offset rear 6 lugs $120
Full size Jeep truck rear axle AMC 20 with one piece axle shafts welded axle tubes to the pumpkin and has 4.56 gears and a full spool 6 lugs complete set up for a yj SOA $180
Dana 300 Double cardian Yoke $40
winch roller fairleads $25
dana 44 mini spool $50
Chevy 203 transfer-case $180
TH350 adapter for 203 $40
TBI wiring harness complete! $50
dana 60 rear Blue Torch Fab truss also comes with a piece that bolts to the diff cover $40
dana 60 open carrier with spiders for 4.10 gears $60
Dana 60 stock yoke $40
dana 60 3.54 gears $75
dana 60 4.56 gears $100
One dana 44 stock ford hub $25
8 pound propane tank $50 each
YJ parts
drop pitman arm $40
passenger side seat bracket $30
front seat belt buckle passenger side $25
fender flares set $60
poly body bushings 8 of them red & 3 of them are factory plain ones $30
tie rod and drag link $40
tan dash parts and grey dash parts $10 and up!
Glove box $25
CJ parts
steering column $80
Windshield frame no glass $50
carberator off a 304 v8 $50
carb for 6 cyl $50
dana 20 transfercase $80
factory tach $30
factory clock needs a new bezel $40
factory speedometer with temp and fuel gauges $45
hood $50
AM radio factory $120
one 15x8" white wagon wheel new $40
CJ5 Parts
soft top bows and hardware $80
factory soft door frames $60
Black soft doors $120
1975 cj5
front lift shackles $40
frame $180
dash panel $80
grill $80
steering column complete $80
transmission cross member skid $80
gas tank $40
gas tank skid plate $20
Early 1960's short CJ hood and grill $160
-This will fit cj years 55-71 with the short front clip
XJ parts
99 side mirrors $40 pair
89 drivers mirror $15
grill middle part black $30
front turn lights $10
front light trim pieces $20
ZJ parts
96 tail lights $40
front lights with turn signals $45
TJ parts
Most of the parts are off of a 97-98 model but will fit other years too.
gas tank with sending unit/fuel pump $180
transmission cross member skid plate $60
rear driveshaft $50
Hood $80
Heavy wall front driveshaft double cardian $120
Soft top door surround passenger side $40
soft top side windows pair black $20
steering shafts for column to steering box $40
4 stock lower control arms $20
windshield gasket $10
door strikers $10
windshield hinges $25
brake booster and master cylinder $80
wiper motor $25
wiper linkage $25
Re: Cj yj tj xj zj parts and some builder parts
Location? Is the CJ windshield beat up?
Can you send pictures of the blue torch fab dana 60 truss to 901-359-2075 please? Also would you be willing to ship?
what condition is the CJ tailgate in and what color is it? Also, what condition is the CJ hood in?
