BurnTables
CNC Plasma Router Tables
BurnTables CNC Tubing Cutter
Attaches to any BurnTable CNC Plasma Table. Allows the use of table with out interfering with most flat plate cutting. It is installed in a way that it allows the use of the length of the table. (On a 5x10 table, you can chuck up a 10' long piece of tube and cut the notch the end!)
3 jaw Self-Centering Chucks; Diameter: 6 (Inch); Jaw Type: Two Piece Hardened Reversible Jaws; Thru Hole Size: 1.570.
$2,500.00
$2,500.00
