Converting 14 bolt hubs to studs and nuts
I just did this on a U4 car I built with almn hubs. Studs and norlock washers with nyloc nuts they never come loose. I think the key when using a bolt however is have a long enough shoulder on the bolt that it goes into the hub alittle so the shear load isn't on the threads but the smooth shoulder . Typically that shoulder is .005 bigger then the thread and stronger . Not all hubs will accept a bolt like that though . Making these studs the way to go
Got me some studs, the last ride the bolts kept loose, and it slung oil everywhere.
Sent from my Pixel 3 using Tapatalk
I tried studs but still had problems. Switched back to grade 8 bolts with safety wire and didn't have any issues for 2 years. I sold the jeep, so I don't know if it still holding or not.
Nice work :dblthumb: Are you an A & P Mechanic? Looks like the way prop bolts are done.
My question is how much of this is caused by, a bent or warped housing do to welding. I never had an issue till I boarded spring perches, on any 14 bolt. Mine was on driver side tube.
What type o
What type of riding are you doing.
Not enough, I guess I might have been leaning more to a question.
But mostly just trail riding / booze cruisen
With mine I just bought spring perches and welded them where they needed to be, but I never had loosening issue before that.
