red94yj
Axles are set up for a sprung over yj. Since I've installed the axles I've only taken it ridding once. Just some local trails around the house. I have put around 200 to 300 miles on the axles. I've only put 50 miles on the rear since it has been re-geared by Offroad connection. When I got the axles the rear pinion bearing was bad and caused the re-gear.
Both axles are 8 lug on 6.5
Rear axle is geared 456 with a powerlock carrier. Rear axle also comes with anti wrap bar mount built by Offroad connection. 3/4 ton caliper mounts are welded on ready for your brakes. Comes with 2 spare axle shafts. No shock tabs. Wms is 64.
Front axle is geared 456, with an unknown brand electric locker, flat top knuckles, high steer arms, and warn premium locking hubs. 3/4 calipers and rotors. Oem steering arm on knuckle is drilled for 3/4 heims. No shock tabs. Wms is 67.
Asking price $750.00
Ready to bolt into your yj
Located in Trussville Alabama 35173
Local pickup is preferred. May be possible to ship via fastenal. I can also meet within a reasonable distance.
Let me know if you have any questions or concerns.
