Dana 60 "Super 60" gearset 5.38 high pinion
PJTPW
Member
Located in Moab UT 84532.
Dana "Super 60" gearset. 5.38 ratio. New, spare for an old rig.
These gearsets are made by Dana Spicer. They are 10" diameter on the ring gear, and have a better aspect ratio (teeth are more curved).
I have shaved this gear down on a lathe so it's 9 7/8 to be a spare for a high clearance housing.
Also have ring gear bolts, pinion bearings, shims, pinion nuts, oil baffles, slinger, pinion seal, etc.
Would like to sell all this together $195.00 Shipped in the lower 48.
Pic1
All new timken or koyo bearings / races.
4 pinion bearings, oil seal, slinger, baffles, ring gear bolts, pinion nuts and washers. Shims etc. Everything pictured.
Are these built for the 05+ super duty 60s that came in the 450/550? If so won't they fit the standard 05+ 60s?
I'm not sure of the exact oem application but that sounds right. They fit any oem hp 60 housing
