Sold/Expired Delete
slim1968
:woot:2012 Buggy For Sale
Kore 54" Defender Chassis with custom front end
21" belly clearance, 75" top of cage, 110" WB, 7" uptravel front, 8.5" uptravel rear
Jim's Fiberglass JK Grille, Hood, & Cowl
Essentially Offroad custom interior €" all aluminum €" front firewall, floor & tunnel all covered with line-x
Custom aluminum dash with Autometer volt, temp, oil PSI & Trans temp gauges €" aluminum center console with cubby hole and 2 cup holders
2007 Chevy 6.0 with LS2 intake, Throttle body & injectors €" Dyno tuned - WOD accessory re-locator kit for PWR steering and alternator €" Kevko pan with Lokar locking braided dip stick €" Summit Racing Headers €" single dump exhaust with Magnaflow muffler
PSC N-Pump, steering valve & reservoir
Performance Torque Converters (PTC) TH400 with reverse manual valve body & compression braking €" HD aluminum deep pan €" lokar locking braided dip stick
Atlas II 3.0 transfer case with HD outputs and 1410 yokes €" standard mechanical shifters
Trans and transfer case vents are routed to an All-Star catch can to prevent spills during a rollover
Front end" EOR built 14 Bolt" 5.13 gears, Detroit Locker, Barnes 4wd Diff high clearance cover - Solid Axle inner C's, knuckles & high steer arms " Yukon Hardcore Spindles and Hubs " RCV nickel plated shafts, RCV drive flanges " Spidertrax 3/8 thick drilled rotors, Willwood Dynalite calipers & pads " all stainless braided brake lines, pinion guard, 1410 yoke
Rear end " 14 bolt €" 5.13 gears, welded carrier, Barness 4wd high clearance cover, Spidertrax 3/8 thick drilled rotors, Willwood Dynalite calipers & pads €" all stainless braided brake lines, stock axle shafts, pinion guard, 1410 yoke
PRC Custom Aluminum 30x19 Radiator €" AN fittings, steam port built in (steam port plumbed with AN/Stainless braided line
Dirt track style aluminum shifter with EOR cable set up €" no detents (other than park)
Fox 2" remote reservoir shocks with PAC racing springs (16" rear, 14" front)
Fox 2" x 4" bump stops on the front
7075 Aluminum links 1.25" heims on the lowers, 7/8" heims on the uppers
Wheels & Tires- Trailready Beadlocks 43" stickies
12 gallon fuel cell with AN fittings/braided hose €" Walbro pump w/ WIX corvette filter/reg
HD driveshafts with 1410 spicer joints - EOR carrier bearing set-up
LED tail lights and reverse lights €" can install a yellow and a blue in the reverse lights to be KOH legal
LED Headlights (2500 lumen per light) & 40" LED Light Bar (Crazy Bright)
Optima Red Top Battery in BTF tray
Brand New Warn 9.5cti w/ 100ft Rope Winch
Corbeau Ultra seats with Crow 3" padded 5 point harnesses
Aluminum roof and side panels
Professionally painted with Ford Tuxedo Black Metallic w/ double pearl
½" 6061 aluminum skid plate
Located Ashland ms 70 miles from jackson tn 60 miles from memphis tn
Price $40,000 obo or trade on nice truck,dually,or ?? Try me text or call dennis 662-224-4848
Re: kore defender buggy
im 6'6" 240 and have plenty of room theres a 7 page build tread , videos,and walk around under dennis kore buggy
Pic
Damn....lots of badass rigs popping up for sale. I'm with Muddin....love this rig.
GLWS
Thanks guys and yes buggy has not been beat on at all
Pic new wrap
Back for sale or trade. Thought buddies was gonna ride I've only took this out 1 time that was greyrock. May trade on dually or ??
ready to trade whenever you are :popcorn:
