Sold/Expired Ford drop NP203
IRONMIKE
O.D.
Lexington, Ky
Hello,
I am looking for a Ford drop NP203. I need this for a doubler. Shifter linkage must be on passenger side of front reduction box. Here is a list of candidates.
•'73-'77.5 F-150/100.
•'77.5-'79 F-150/100 and F-250.
•'78-'79 Full-Size Bronco.
Thanks for looking,
Ironmike
Here are some pics of a ford vs chevy NP203. I am no expert, but I need the one with the shifter linkage on the right. I believe that is a ford. This may not be possible to mate it to a TH350. We will see I guess.
Why do you want a ford 203? If your doing a doubler and need drivers drop then that's the ford 205. ORD has kits to mount ford 205 to chevy 203 and vice versa.
InittowiniT,
I want the ford 203 so that I can rotate it 90 deg and have the shift shaft in the top position. When you use the chevy drop and rotate it 90 deg the shift shaft is in the down position. That seems to me a great place to have a leak. So Ford 203 rotated 90 deg with the shift shaft rotated up. Then run that to a chevy 205. ORD does not offer that as a hybrid. They also did not want to work with me to make one. NWF does not care what combo you want to run, they will work with you.
Boz,
Is that the going price? That seams like top dollar. I mean I just saying.
Thanks,
Ironmike
I forgot about this thread. My bad,
IMO for a Ford 203 that is a fair price. They are the rarest of 203's. I have only ever seen a few in person. I can wiggle on it. Make an offer if u still need it.
