front locker
hinton
first trip out in my rig and the front lockrite is slipping very bad, so what is everyone running with good luck been thinking detroit. its going in a chevy d60
pretty much everyone I have talked to about lockrites for 60s have liked them and havent had any issues with them......something not installed right? :dunno: I dont really know **** about them, my front is welded solid!
its installed right i just have run that locker in my old rig for about 3 years and i am not easy on things, but this is the 2nd one i have seen do the same thing mine did just looking at a better locker
I ran my lockright for about 3 years then it started slipping then wouldnt lock up at all so I just took the welder to it now there are no parts to break.
If its new and slipping you have a side gear thrust washer problem. There is a minimum thickness
-Jimmy
Chase at ECGS can send you a set of shims for the thrust washers... Look up the specs, the tighter the better... :cougar:
