hjpcummins
- Joined
- Oct 11, 2011
- Messages
- 1,510
Another one bits the dust!
Guess no more 5.29s for this heavy foot
Skidkid said:I know toy R&P are weak but I'm wondering if this was setup right to begin with. I've taken a bunch of teeth off of ring gears and never to the outside like that. I'm thinking the pinion wasn't deep enough in the ring gear.
bluetoy said:That's not normal gear breakage. Definitely wasn't right to begin with. A properly set up 5.29 should hold up good in that rig with it being as light as it is.
However, I personally am not a fan of a spool in a Toyota diff. Because of the really small diameter of the spool, you get a ton of ring gear deflection under extreme load. A spool is just not nearly as rigid as a bigger carrier such as a stock diff or full case locker. Deflection is what kills ring gears. Anything you can do to minimize it will make your gears live longer.
rednecklights said:looking good! sorry I didn't get a chance to call you back tonight. I will give you a shout tomorrow evening.
Sent from my C771 using Tapatalk 2
Blase said:You've got this thing headed in the right direction!! hats off to you for not giving up after what happened.
