I would be worried about hanging up on things more then a strength issue.
That was the argument when I did mine too.... it's been a non-issue.
and Crazy's pic of a front end is from a different rig. That's NOT the same rig as the pic of the back shock/coilover brackets that Clark cut for Dean
Arm chair engineer here
Edit: Wheres JasonC??
Arm chair engineer here, But im thinking it's a extra burly 3/8ths wall axle tube. Depending on the depth of cut of course. That truss may null and void any issue though.
I'm thinking they're 1/2" tubes. :redneck:
They are 1/2 tubes.
Hey Aventeone,
I wanna pick up that Atlas shaft today. What beer you want?
Tony
Just some Coors Light for the shop fridge.
Your supposed to ask for good beer :awesomework:
Adding another engineer's take on the fluting topic... Cisco is correct. Removing material will not make a structure stronger or more rigid (except possibly in some particular circumstances involving stress concentrations... but that's definitely a topic for a separate thread and doesn't really apply to barrels or axle tubes, for the most part). We all know adding ribs increases rigidity, and that holds true for flutes. Fluting a larger diameter tube is basically the same as adding ribs. But again, a fluted tube is less rigid than a non-fluted tube of the same dimensions.Cutting into the axle tube does not add strength. Adding ribs on the outside would.
With barrels, the main benefit is the increased surface area... better heat dissipation. But, that has to be balanced with the loss of heat capacity from the loss of material.
