How to reverse the gears in a rockwell axle for a rear engine rig.
budsmud
Active Member
How to reverse the gears in a rockwell axle or where to fine the info on how to reverse the gears on a rockwell axle
I'm working on a rear engine truck.
Re: how to reverse the gears in a rockwell axle
Ive never worked on a rock but I think you just rotate the 3rd 180 degrees then drill a few new holes in the housing for some bolts that dont line up.
Big thread on pirate. If I remember correctly you have to do very little machine work of course along with the gear flop
That wont reverse the gears, that only gets the drive line in the center of the axle.
you have to flip the pinion around not hard to do but machine work is needed
Look up fishmouth fabworks on pirate he did it a couple of years ago.... the input gear has to be turned around its a worm gear... one bearing is smaller than the other so u have to machine one end out of the housing to accept the larger bearing and on the other end need to make a spacer to hold the smaller race and bearing and that's it.
Re: Re: how to reverse the gears in a rockwell axle
Details with pics in this thread:
http://www.pirate4x4.com/forum/showthread.php?t=385308
Sent from my DROID BIONIC using Tapatalk 2
Re: Re: Re: Re: how to reverse the gears in a rockwell axle
Well, the pics aren't working for me now, anyone else?
Here's another with a couple pics:
http://www.pirate4x4.com/forum/showthread.php?t=460597
Thanks for the replys ,I found kevin barrell of Coosa 4x4 in Rome ,Ga . for any more information please contact kevin barrell at 706-237-6519 he can reverse the gears in my rockwell axles
This is for a rear engine mud truck that I,m putting together.
Your right ,flip the pinon gear and machine the housing to fit the bigger bearing
