Hp dana 60 brakes need help
collinmaune
I have a hp dana 60 under my buggy and it has the stock caliper brackets that attach to the spindle I'm having a hard time finding the right hardware kit or pictures of how to install the hardware kit correctly. Any pictures or diagrams would be great.
Install hardware kit - H5533 (both sides included)
Caliper bolts - H5011 (both sides)
I finally gave up on mine, after re-making the caliper spacer thicker several times for both sides, the caliper mounts just kept spreading out and the calipers would start moving back and forth making all kinds of racket. Get with Gubni and up grade the whole shebang. Lugnut 4x4
Or make brackets and run FJ80 Calipers with Chevy rotors
Have you tried these out yet? How much better do they work than the 3/4 ton chevy stuff? I haven't too happy with my 3/4 ton chevy stuff and have 4 Tacoma calipers left over from my Toyota axle days that I would like to use. I will need to find a 10mm to -3AN brake line fitting to work with my lines.
Haven't drove it yet, and I came from factory Ford calipers on worn out and bent brackets, so my comparison won't be a good one. I don't like the idea of a sliding caliper offroad. I have Chevys on the rear and will likely go to the Toyotas on the rear too if the fronts work good.
