kturner
It's not a good time til something gets broke!
I was wondering if anyone else was using Blackbirds customs Chevy caliper brackets on a Ford high pinion 60 ? When assembling mine I noticed that they send a caliper bracket and a 1/4 inch shim ring also. When these two are combined there is very little ,basically no shoulder left on the spindle to ride in the knuckle .I tried to leave the 1/4 shim ring out and then the inside brake pad would fit between the caliper bracket and the rotor.
I feel with thickness of the caliper bracket and the shim ring there is not not enough of the shoulder on the spindle riding inside the outer knuckle . It appears that the spindle is relying soley on the five 3/8 bolts to hold it in place .
Anyone encounter this problem ?
