scottsoutwheelin
- Joined
- Dec 16, 2009
- Messages
- 131
Thanks for all the views and all calls buggy is NO LONGER FOR SALE.
Something came up for sale that I really want so if it sells before this sells then I will no longer want to sell mine. This is a Jimmy Smith Chassis (max), Chevy 60 front, 513 gears, long field drive flanges, chrome molly 35 spline shafts, solid diff covers, poison spider high steer arms, 3 qtr ton brake conversion, rear is 14 bolt 3 qtr ton brake conversion, 513 gears, solid diff covers, psc pump, psc reservoir, psc double ended ram, motor is '06 lq9, ceramic headers, wiring harness reworked by Jim's Performance, advanced adaptors flex plate, computer flashed no security, no emissions, approx 400 horse, 370 lbs torque, transmission turbo 350, rebuilt with racing clutches and extra clutches, manual valve body, 205 transfer case with clokcing ring (clocked), twin sticks (have Ford 205 for output shafts), all Rockwell drive shafts, all new hime joints, aluminum links are 70/75 on bottom and steering, 60/61 on top, 44 inch TSL's and custom bead locks, already has aluminum custom fuel cell built with pump, has Fox 16 inch coilovers with springs, and much more!!
Things to finish: Air Bumps (have cans), Winch, hydralic lines, brake lines, battery box (have new odeyssey battery), drive shaft yokes, fuel lines, coolant lines, torque convertor, brake pedal and master cylinders, gas pedal, and powder coating.
Price is $22,500.00 - If Interested Call or Text Scott @ 931-639-7775.
