Sold/Expired ***Jimmy's 4x4 four seater buggy***
TXcrawler
***Jimmy's 4x4 four seater***
Looking to sell my jimmys 4x4 rig. This has been a great family buggy and can go up anything you put in front of it. Here's is the parts list
Located Crosby, TX (just outside Houston)
$40,000 would trade for a lesser rig in the 20k range and cash on your end....hard to justify a buggy this nice that only gets used 6 time a year
Call/txt 281-541-6498
BUGGY 4-TYPE
CHASSIS 4-seat, 1.5 x .120W DOM
1St Series-(Podium series)
Bumpers
Truck pre run-front
Single tube rear
Skid's
Engine Skid Plate with UHMW
Side Nerf Bars Pair (Includes Install Time)
shocks
RADFLO
Single shocks 2.0 coilover w/springs, 12" Front and 14" Rear
Radflo Bumps
Suspension
SUSPENSION;
ROD END KITS W/SPACERS
3/4x5/8 UPPER, 7/8x3/4 lower C-Molly Rod Ends, Stainless spacers and Washers
DOM links regular Rod Ends
Steering
Steering – Dual Cylinder
PSC, full hyd kit, (TC/"P") Pump, Steering VALVE (3.5 turns, other valves are available), COLUMN for Steering WHEEL), RESERVOIR (6" reservoir w/low pressure hoses), Hi-Pressure HOSES AND FITTINGS, DUAL 2.5 RAM, Small ENDS, END LINKS (Rod ends and dom tube),
PSC steering wheel Disconnect hex
Coolers
Derale 18" log cooler
Plumbing
Base PLUMBING KIT—Push Lock, Regular kit
Fuel and Cooling & Brakes
Fuel Cell- Aluminum tank no foam
Advance metal Fab- 15G
Brake kit
wilwood dual master
CUTTING BRAKE
DUAL HANDLE, Two pull Levers
COOLING
Radiator, Griffin Custom dual pass w/ dual elec spal fans and mount,
Expansion/Overflow tank
Wiring and Electrical
Wiring supplies W/OUT Lights
Master kill switch, optima Red top,
Rock-Lights
qty4 –led rock light strips round eyes (under car)
Rigid Industries spot or flood
10" E Series Rigid Industries top light HEAD LIGHT
30" E Series Rigid Industries top light OVER HEAD TOP LIGHT
mounted in light bar (protect for roll over)
Body and Interior
Body-
Floor and firewall, doors, front kickers, rear kickers, rear splash guard (behind seats), ROOF, INCLUDES TABS To Attach to Chassis
dash- Full Dash
Front & Rear Clips
Universal/Escalade Hood and Cowl, Rear aluminum panels
Accessories
Seats
Twisted Stitch Black apex
Seat belts
G-Force.. Base 5 point, new fronts used rears
EXHAUST
DUAL EXHAUST, CLAMPS, MAGNAFLO BULLET MUFFLERS
WINCH
WARN M6000 Short Drum W/Master pull winch rope 50' x 3/8
Paint and powder coat
Powder Coat
Chassis, small parts (radiator mounts, engine mounts, trans-mount, all clamps and Brackets, window net hardware) axle housings/Knuckles/diff cover
Body Paint/PC
Paint outer body hood, cowl, febders and grille, Powder coat all interior panels
Motors;
LS1 Used packaged Turnkey Engine
Truck Intake, LS1wiring.com Harness and Re-Flash Computer, New Air Filter. Fuel Pump and Filters, F-Body Pan
Transmissions/Kit;
Rebuilt Transmission
THM350
TH350 HD "B"
This is a short OEM 4wd shaft, HD Intermediate drum with Sprag and HD outer Race, large low roller clutch/Ceter support (700r4), all v8 cores no 6cyl cores (5 Friction FWD & Direct Drums). Transgo shift kit (Can use FWD shift Full Manual, with HD converter (Furnaced Brazed), AN fittings at the cooler and transmission vent drilled for ¼" barb. includes dipstick and indicator, also comes with a Gate shifter.
Coolers; (has 8x10 hurricane brass single pass)
Griffin 10x12 dual pass aluminum Cooler (used)
Transfercase; No speedo, Regular yokes
Stak 2-speed Monster
Stak Thm 350
AXLES
FRONT Complete
Base D60 OEM
OEM GM D60 housing, Standard tube, OEM c's, New Solid key'd Knuckles, new King pin Kits, 7075 Aluminum steering arms Key'd, all king pin Hardware,
Factory wheel hub (8 lug) spindles, spindle nuts, New wheel bearings and seals, Grizzly locker, New D60 R&P (5.38 ratio), Master bearing and seal kit, 1350 yoke U-Bolt, HD cast cover, c-molly shafts, Nitro u-joints, 35 spline D-Flanges, Factory Brake plate's and OEM cast Caliper
REAR AXLE, COMPLETE- NON REAR STEERING
Base GM14T
OEM GM 14T, Factory Full float spindle, OEM wheel hub (8 lug), Factory spindle nuts, New wheel bearings and seals, Used OEM carrier with Detroit Used, (5.38 ratio), Master bearing and seal kit, 1350 yoke U-Bolt, HD cast cover, Factory 14T shafts, Brake plate and OEM cast Caliper stopping cast Rotor. ADD 14T shave kit
Pic
Cut Boggers? Nice.....how about some more pictures and details of that 60 in the back ground!!!! :dblthumb:
More work than you will ever know went into those tires and I'd like to keep them. Rig will be sold with a set of 43's TSL on 17" trailready aluminum Beadlocks
