Sold/Expired Jimmy's 4x4 four seater
TXcrawler
Selling my 4 seater Jimmy's 4x4 rig. It has only been wheeled 7 or 8 times since it was rebuilt by Jimmy's 4x4.
Located Houston, TX
$47,000 obo. Will deliver anywhere in US for the right price
BUILD SHEET FOR OFFROAD TURNKEY BUGGY 4-TYPE
Motor
LS1 packaged Turnkey Engine
Truck Intake, LS1wiring.com Harness and Re-Flash Computer, New Air Filter. Fuel Pump and Filters, F-Body Pan
Transmissions/Kit;
THM350
TH350 HD "B"
This is a short OEM 4wd shaft, HD Intermediate drum with Sprag and HD outer Race, large low roller clutch/Ceter support (700r4), all v8 cores no 6cyl cores (5 Friction FWD & Direct Drums). Transgo shift kit (Can use FWD shift Full Manual, with HD converter (Furnaced Brazed), AN fittings at the cooler and transmission vent drilled for ¼" barb. includes dipstick and indicator, also comes with a Gate shifter.
Coolers; (has 8x10 hurricane brass single pass)
Griffin 10x12 dual pass aluminum Cooler (used)
Transfercase;
Stak 2-speed Monster
AXLES
FRONT Complete
D60 OEM
GM D60 housing, Standard tube, OEM c's, New Solid key'd Knuckles, new King pin Kits, 7075 Aluminum steering arms Key'd, all king pin Hardware,
Factory wheel hub (8 lug) spindles, spindle nuts, New wheel bearings and seals, Grizzly locker, New D60 R&P (5.38 ratio), Master bearing and seal kit, 1350 yoke U-Bolt, HD cast cover, c-molly shafts, Nitro u-joints, 35 spline D-Flanges, Factory Brake plate's and OEM cast Caliper
REAR AXLE, NON REAR STEERING
OEM GM 14T, Factory Full float spindle, OEM wheel hub (8 lug), Factory spindle nuts, New wheel bearings and seals, Used OEM carrier with Detroit Used, (5.38 ratio), Master bearing and seal kit, 1350 yoke U-Bolt, HD cast cover, Factory 14T shafts, Brake plate and OEM cast Caliper stopping cast Rotor. ADD 14T shave kit
CHASSIS 4-seat, 1.5 x .120W DOM
(Podium series)
Bumpers pre run-front, Single tube rear
Skid's
Engine Skid Plate with UHMW
Side Nerf Bars Pair
shocks
RADFLO
Single shocks 2.0 coilover w/springs, 12" Front and 14" Rear
Radflo Bumps
Suspension
SUSPENSION;
ROD END KITS W/SPACERS
3/4x5/8 UPPER, 7/8x3/4 lower C-Molly Rod Ends, Stainless spacers and Washers
DOM links regular Rod Ends
Steering
Steering – Dual Cylinder
PSC, full hyd kit, (TC/"P") Pump, Steering VALVE (3.5 turns, other valves are available), COLUMN for Steering WHEEL), RESERVOIR (6" reservoir w/low pressure hoses), Hi-Pressure HOSES AND FITTINGS, DUAL 2.5 RAM, Small ENDS, END LINKS (Rod ends and dom tube),
PSC steering wheel Disconnect hex
Coolers
Derale 18" log cooler
Plumbing
Base PLUMBING KIT—Push Lock, Regular kit
Fuel and Cooling & Brakes
Fuel Cell- Aluminum tank no foam
Advance metal Fab- 15G
Brake kit
wilwood dual master
CUTTING BRAKE
DUAL HANDLE, Two pull Levers
COOLING
Radiator, Griffin Custom dual pass w/ dual elec spal fans and mount,
Expansion/Overflow tank
Rock-Lights
qty4 –led rock light strips round eyes (under car)
Rigid Industries spot or flood
30" E Series Rigid Industries top light OVER HEAD TOP LIGHT
mounted in light bar (protect for roll over)
Body and Interior
Body-
Floor and firewall, doors, front kickers, rear kickers, rear splash guard (behind seats), ROOF, INCLUDES TABS To Attach to Chassis
dash- Full Dash
Front & Rear Clips
Universal/Escalade Hood and Cowl, Rear aluminum panels
Accessories
Seats
Twisted Stitch Black apex
Seat belts
G-Force.. Base 5 point, new fronts used rears
EXHAUST
DUAL EXHAUST, CLAMPS, MAGNAFLO BULLET MUFFLERS
Wheels and Tires
Trail Ready 17x8.5 w/4.75" BS, Aluminum Ring
Stan internal Beadlocks
43x14.50 TSL SX non sticky
Options accessories
WINCH
New WARN M6000 Short Drum W/Master pull winch rope 50' x 3/8
Paint and powder coat
Powder Coat
Chassis, small parts (radiator mounts, engine mounts, trans-mount, all clamps and Brackets, window net hardware) axle housings/Knuckles/diff cover
Body Paint/PC
Paint outer body hood, cowl, febders and grille, Powder coat all interior panels
Sharp Ride!
If you click in the IMG code under "share links" on your photobucket, it will copy it and then you can paste it here
That is all I did just now, hope this helps
Thanks for posting pics! It's a great buggy just got done putting all new switches in
Pic with the 43's
Price lowered to 47k! Will have this rig at Burris Valley Ranch next weekend the 8th of August if anyone would like to come check it out
I'm available if you want to come check it out. Give me a call 281-541-6498
Will have this rig at Hot Springs next weekend if anyone wants to check it out
Horsepower hill this weekend at hot springs
https://m.youtube.com/watch?v=RHG1LKYMb_0
