B
Badride
Guest
I am looking for a tuner in Georgia. Engine dyno would be best.
I haven't. I had tick performance in Mount Airy, NC build mine.Badride said:Have either of you used them? Neither one have an engine dyno.
Mortalis5509 said:I haven't. I had tick performance in Mount Airy, NC build mine.
Sent from my SM-G935V using Tapatalk
pholmann said:Make the ride over to Huntsville Al and let Lane Culver have it for a few hours. He knows his ****. Definitely worth the 350$.
Badride said:I know he did your's. He only tunes it wide open? Only three pulls?
I am changing everything on this build. I need more than just a stock tune changed a little bit.
And he only has a chassis dyno. Right?
Jduck said:He'll do as many pulls as it takes. Not sure what you mean only tunes wide open?? When he did mine he'd run it up in rpm's gradually a few times doing something on his laptop then do a full pull. I drove past a bunch of shops to get to his because I feel like he has a good understanding of what we need and expect out of our engines vs a shop that only does street cars and full on drag cars.
Badride said:Just asking. The videos you see are only of a WOT pull. With changing the injectors and cubic inch. I will need a change in the VE table which is what all the other calculations are based off of.
Jduck said:Who wants to watch a partial throttle video..
Badride said:You are always pushing Tick Performance. So do they have an engine dyno and do tuning?
With all of your " Racer " this and that, you would know right?
How did your build do on the dyno? Not what the guy said it should make. What it actually did !!!
