Sold/Expired Ls2 aluminum and iron block
NTIDWELL
Have a 02 iron block 6.0 with 100k miles complete mins starter and power steering pump stock bottom end daul timing chain high flow oil pump ls7 lifters and springs comp cam 595/598lift 232/234duration 112lobe separation 317 heads truck intake comes with ecu already tuned harness 3wire hook up ready to go an fittings on water pump and thermostat ready to run this motor is dbc. $3500obo aluminum block SOLD call or text 5732758213 located in Friedheim mo
Aluminum block
Iron block Dam video wouldn't work anyways u can hear iron block run. Aluminum block runs but got a tick and 30lbs of oil pressure
  • capturedvideo.MOV
bighook said:
Why you selling motor out of buggy? :dunno:
new direction taken the aluminum block to motor guy tomorrow find out what for sure is wrong will not sell iron block till after hot springs
toreadorranger said:
am I reading that right? Stock LS2 with a spun bearing for 5k?
yep thought it was a bearing talked to motor guy today just bad oil pump it will be repaired
