Custom built Rock Crawler ( rockcrawler ) tube buggy with 5.3 LS motor. This is an American Rock Rods 4 seater Mantis chassis made from 1 3/4" DOM tubing. It is set up as a two seater buggy currently. Dana 60 front axle with 5:13 gears, chromoly inner and outer 35 spline shafts with drive slugs. GM 14 bolt rear with 5:13 gears and stock shafts. Both axles have welded differentials. Full PSC steering system will double ended ram. The motor was from an 03 Tahoe and has a cam swap with custom tune and a big Be Cool aluminum radiator. The harness and computer are from Affordable Fuel Injection. It has a 700r4 transmission with a twin stick Atlas transfer case with 4:3 ratio. Wilwood brakes with front and rear pedals. It also has a bluetooth stereo with marine speakers and Corbeau suspension seats. It uses Fox coilovers at all four corners with Fox bump stops and a Currie Antirock bar on the rear. The heim joints on the link bars are all 1 1/4". The wheelbase is 124" and it has 44" TSL Super Swampers on double beadlock wheels. They have 4 trips on the tires and the complete ride has about 12-14 trips on it. This buggy works very well, is stable at crazy angles and the motor is very healthy. Don't want to trade. $22k. Travis 281-703-2415. Located in Huffman, TX.
