1TONZR2
Big mudda fugga!
well, its my turn. I have been wanting to build a buggy for quite a while now and while on deployment I was able to decide on what exactly I wanted to build and start getting things in line to do so. So here we go...
Chassis: HellRaiser 3 from AZrockcrawler.com
got my plans a few days before I got home from deployment
This chassis design is actually designed around 3 single seats, not 2 seats and a bench. After talking with Chris about it, he said a bench will fit with no issues. I plan on making a few changes to it since I am a little taller than most. It will be stretched a bit and probably have a little taller cage height (hopefully not much). Also, this chassis was built with a V6 and a rear radiator, but there have been a few people use LS motors like mine and a front mount radiator, only thing it will do is raise the hood line a bit. By keeping the radiator in the front, I will be able to push all the seats back a little bit to help with leg room.
The ZR2 truggy will be dismantled after its last ride this fall and the majority of the parts will be used on the buggy.
Things I will be keeping:
5.3L Vortec, 4L60e, 231/205 doubler
Aluminum radiator w/ taurus fan
B&M pro stick shifter
dual cutting brakes and brake lines
Warn 9.5ti
D60 with 5.13s, chromos, RPM drive flanges, solid knuckles and arms, welded up, 3/4 ton brakes, ruff stuff cover, trussed
14B with 5.13s, disc brakes, detroit, ruff stuff cover, trussed
16" ORI's
full hydro steering--Dual ended Performance offroad Systems ram, PSE pump, Howe tube cooler
42 PBRs on trail readys
Things I will be selling:
Truggy chassis, with wiring harness for a 5.3/4L60E, links, belly pan
2 PRP daily driver seats
RCI fuel cell with remote fill tube
possibly the 16" SAW coilovers and 4" SAW bumps
I would REALLY like to make a package deal with all this stuff......
Things I have already:
Bunch of parts from Jegs-
Gauges, steering wheel w/ disconnect, steering ujoint, brake pedal and 3/4" masters, magnaflow muffler, trans cooler, lots of fluid lines and fittings, fuel filter, fire sleeve for all the fluid lines, throttle pedal and cable, exhaust wrap,
PRP Comp High Back seats with the +4" height option. They are all pleather material, black on the back, black carbon fiber on the sides and charcoal carbon fiber in the center with silver piping. They also have some mesh where the butt section meets the back section so water wont collect in them.
PRP bench seat...38" wide, made with 3" taken out of the seat bottom for a little more leg room and the colors are the same as the front seats.
pic with one of my passengers
PRP 3" H style harnesses. the padding and chest buckle are standard...these things are NICE!
More to come......
Warn 9.5ti
16" ORI's
More to come......
