Sold/Expired Need Th400 or TH350 with atlas adapter
zeb3
Looking for a th400 or th350. Preferably one that is ready to go with 1800-2600 stall TC. I'm from North Alabama if anyone has one close.
Re: 4wd Th400
I have one that was mated to an np205 using an adapter from behind earlier style sm465. Output shaft is 10 spline to be used with power sleeve inside the adapter that is used with the early style 10 spline np205 tcases mated to the sm465. Bought it in working condition but only for tcase and adapter to use with a manual. Only known defect is 1 bolt hole is broken off the upper side of the bell housing. $100. Located in prattville, al 36066
Re: 4wd Th400
One shot of the broken bolt hole in the bell housing, upper right when looking at the bell housing. Was run as is with that bolt hole missing.
Re: 4wd Th400
I have a few but I'm not real close. Michigan. You need any certain tailshaft? There's multiple different ones for different transfer cases
Re: 4wd Th400
Not sure what tail shaft he needs. He's planning on running it to a NWF Black Box / 205 combo
