Ok I have a 4 seater buggy that I'm going to sell
It's all new just finished a few months ago with only a dyno trip and one wheeling trip on it.
It's sitting on a new set of 44 boggers with a 5th for a spare
H1 rims with pvc inserts powder coated blue and orange
Dana 60 front with 5.13 gears locked with 35 spline shafts full artec truss
Mile marker Ss lockouts
Full hydro
7075 aluminum tierods 3/4 hiems
Blue tourch diff cover
4linked
14 bolt rear shaved with 5.13 gears and disc brakes
Pinion hard full artec truss
4 linked
7075 2.5 aluminum links uppers and lowers with 1.25 hiems
All stainless steel braided brake lines
Wildwood dual master cylinder pedal setup
Rear drive shaft is 3.5 3/8 wall cv drive shaft with all 1350 joints
Front is 2.5 1/4 wall two piece with 1350 joints
347 Stroker built with all the best parts
Trick flow intake
Pro-m mass air setup
It's a 87 block with whites performance Stroker kit
Thumper heads with Chevy roller rockers
Bbk fuel rails
Bbk fuel pressure regulator
All braided stainless steel lines set up to run e85 if you want but runs on premium pump gas now
Full March pully and aluminum bracket kit for the front
Psc power steering pump
Ford racing wires
Ron Francis stand alone harness
C-6 trans fresh rebuild with diesel internals rated at 1000 hp
Behemoth drive lines billet aluminum Dubler 5.9-1 ratio
Mated to a 205 t-case that's freshly gone through with a behemoth drive lines rear billet support ring all 32 spline 1350
It's shifted with a jp fab billet triple stick cable shifter and the trans has a art car in dash shifter
Skid ate is 1/4 aluminum sheeted with 1/2 cut board full belly
All aluminum body panels
All aluminum floor
Aluminum dash
Race pack in dash set
Bbk in dash fuel gage
12 volt guy switch panel
Tri cup holders
In dash marine radio the circle style just plug your phone in and go
Two 6 inch speakers in the tunnel up front
Two kicker rear wakeboard tower speakers in the rear all the wires are ran thru the chassis
Carbo seats front and rear with 3 inch five points cam lock belts
T-max comp winch in the front
16 inch ori front
18 inch ori rear
Rci fuel cell
Holly dominator fuel pump
All an fittings
Tail lights and turn signals
Large light bar in front
Aluminum race radiator with electronic fan
Derail trans core with fan for trans
Derail trans cool with fan for full hydro
All an fittings with stainless braided lines
Dual optima yellow tops up front
High amp alt
High out put water pump
Aluminum valve covers
Msd rev limiter
Everything is fused and relayed
Limit straps all the way around
Spin tech mufflers with dual exhaust fully wrapped with blue header wrap
Bbk headers stainless
Copper header gaskets
It will come with a custom blue safari top with orange stitching
The chassis was originally built by bj from rock solid as a two seater and then turned in to a 4 seater all 1.75 dom tube the belly is .25 wall
The whole set up comes in at just over 4500 pounds. I'm sure I'm forgetting something but this is a sharp clean rig! Looking for $40000 or possibly trade plus cash for jeep or hot rod
Full hydro
4linked
4 linked
Trick flow intake
Bbk fuel rails
Ford racing wires
All aluminum floor
Aluminum dash
Tri cup holders
16 inch ori front
18 inch ori rear
Rci fuel cell
All an fittings
High amp alt
Msd rev limiter
![f82e0c2bf69eacbc160040ffd506f3f6.jpg](http://images.tapatalk-cdn.com/15/05/25/f82e0c2bf69eacbc160040ffd506f3f6.jpg)
![da968921e55d036771ef152180e3308f.jpg](http://images.tapatalk-cdn.com/15/05/25/da968921e55d036771ef152180e3308f.jpg)
