atvredneck76
- Joined
- Aug 10, 2011
- Messages
- 49
Outing back up for sale with more work done and more parts
i am putting my rock crawler project up for sale need something street worthy
frame and cab:
long wheelbase full size chevrolet frame
square body s10 cab
full competition engineering roll cage on the inside
corbuea suspension racing seats and harnesses
roll bar on back of outside of cab and infront of motor over radiator to protect them
engine:
355 small block chevrolet
x rods
flat top pistons
double hump headswith chromolly keepers double valve springs roller rockers chromolly pushrods pollylocks and alot of port work
extreme energy 4x4 cam
highrise intake with holley 650 double pumper
stock chevrolet radiator
3200 stall torque converter
350 turbo transmission
205 gear drive transfercase
axles:
rearend is an eaton punkin rearend with disk brakes and 4.56 gears
frontend is a dana 44 with 3.73 gears just gone threw
tires;
44 square lug turf tires on rear
38 wore out boggers on the front
suspension; leaf springs front and back
whats needed to complete:
shifter
fuel pump installed
driveshafts built
transmission crossmember mounted
front brake calipers put on
wiring
fuel tank
parts i have to go with it:
2" sch80 seamless pipe to build driveshafts
mr gasket high flow electric fuel pump (105gph)
high flow fuel regulater
cb and antenna
newer battery
transmission mounts
driveshafts ends and slip yokes to build driveshafts
i think thats about it i was building it for myself so everything has been done right and with a little work to finish it you could have a tough truck to beat on and climb whatever you want to climb price is $1800 obo or may trade for guns Toyota 4x4 samurai or cherokee please call or text 423-475-3499 located in soddy daisy, tennessee
http://chattanooga.craigslist.org/cto/4109240272.html
frame and cab:
square body s10 cab
engine:
x rods
flat top pistons
axles:
tires;
shifter
fuel pump installed
driveshafts built
wiring
fuel tank
cb and antenna
newer battery
transmission mounts
