Pro Rock Stock Class XJ Build
Started on the rear shock towers today.Jeep has some rust for sure in the passenger rear.Made them tall and wide enough for the intention of running some bypass in the future.
Sent from my SM-G950U using Tapatalk
Re: Re: Pro Rock Stock Class XJ Build
mightymouse said:
when you get it dialed in do you plan on hosting a race at your place?
Already have the VIN class stuff going at the park.Next race is August 17th.I will probably run exhibition only to keep people happy.
Finished the towers today and man it stiffened this thing up even more.All 3/16 steel was used.Tied into the inner shell on the jeep and the rear stiffner.Then a cross bar to tie them together.l left enough room to eventually run a 12" 2 or 3 tube bypass.The rusty cheapos will do for now
How's she doing? Crazy how tiny she is! My sons first roommate in the nicu was a 27 week premie. Amazing what they can do these days.
We hit 3 lbs today and her lungs are about to normal capacity.Plan on doing some rust repair in between visits on the jeeps floorboards and get to mounting some corbeau seats finally.
The replacement axle for the polished turd has started.Picked up the dana 50 for the 9in front build.Thinking $50 was a good deal.Want to run 5x5.5 on the front and rear.Going to get UBs redrill/
bored for 35 spline from Branik and try to make my own brake kit.Might have to drop the coin on branik hats and rotor down the road but we will see.
Bent,bolted and welded into place slow going but I'm happy with the progress
Pretty successful weekend floors finished,seats mounted,dana 50 striped and Cs cut.And most important time with Bailey.Looking like she will be home by the end of the month.:dblthumb:
BIG progress for the little one.Was told Tuesday she will be home by thanksgiving.
Posted the front axle,steering and tcase for sale sold in 30 minutes.Front 9in is in full swing.
Started working on the inner C bushing/tube reducer.Kinda cut the Cs a little crooked so made my bushings a little long to get a set lenght.Machine a peice to stop the tube a .25in from the end of the C like the dana 50 wash.Then made my reducer bushing for the 3.5in to 3.25in tube out of 3.5x.25.Press right in and bored the bushing to .005 over the 3.25 tube dia for a nice slide on fit to set caster later
Nice build. I've really enjoyed it so far. Looking forward to more. Always nice to see some lathe work.
