just mounted up a ps steering cooler from the junkyard and noticed it was 5/16 in/out (tranny cooler), and my ps line is 3/8. i can get it hooked up with 5/16 hose fine. should i run it, or get a 3/8 one? its on the low pressure line.
HEGH?:masturbanana[1]:get a 3/8" one. it dosent sound like much but you can move a lot more volume of fluid thru the larger hose and cooler lines thus cooling it better. restricting it down to 5/16 will cause a restriction and could cause your fluid to be warmer than it was before.
Stick with the one you got, if it mounts easy. 3/8" vs. 5/16" isn't significant enough to make a difference for a steering cooler. The cooler is rated for an automatic transmission, that generates a significant warmer temp than a PS pump. Just having the cooler alone is a drastic difference. A temporary increase in pressure across the cooler (metering) will increase the heat rejection, & if it's in the winter, you can pack snow over it.
I recommend using a transmission fluid filter on your return line, just incase any debris gets loose, it wont take out your pump.
I'm running one out of a jeep cherokee.
hmm, well maybe ill get a bigger one. doesnt make sense to me to speed up the flow through the cooler portion.
You do what you want. Metering flow is called "coefficient" & makes total sense if you go to school. As mentioned before, a higher pressure fluid dissipates temperature more efficient. The actual PS coolers they sell, actually have a heat sink metering device. Going with a smaller line engineers this factor in already.
QUOTE]
:hi:
:corn::haha:
Not flipping ya crap in any way, but............
School is in and time will tell
I have to change pumps every couple years, but I consider that maintenance.
You didn't mention you were having pump problems.
