Sold/Expired RCV RZR parts - 300M Balljoints and Axles
RCV PERFORMANCE
Strongest Axles on the Planet
Rockford, IL
RCV Polaris RZR Axles and Balljoints - available for RZR XP900, and RZR XP1000.
http://www.rcvperformance.com/categories-cv-axles.aspx?catID=RCVP_UTV_PRODUCTS_ALT
RCV Performance Products is introducing the new "Pro Series" axles for the Polaris RZR. The new axle is in addition to the existing "Ultimate" line of axles for Polaris machines. The new axles feature a plunging inboard CV with 300M internals, a 300M axle shaft, and RCV's patented Spherical Sealing Technology CV boot on the outer, providing much greater resistance to punctures and tears than a rubber CV boot. A common failure in the Polaris RZR is the front outer CV. To address this, RCV's outer CV is capable of angles up to 45 degrees to nearly eliminate the possibility of bind when the suspension is at full droop and full steering lock.
http://www.rcvperformance.com/categories.aspx?catID=RCVP_UTV_PRO_SERIES
We are excited to be a part of the Rugged Radios "BAJA RZR". Featuring long travel HCR suspension and RCV Pro Series axles.
These axles have been put to the test in the RZR rockbouncing scene. If you're looking for the strongest axle available let us help!
