Reddragon
New Member
Relentless Rock Bouncer
Chassis was built by Dean Lickliter
Built 6.0 LQ4, 823 heads, baffled shallow mount oil pan, custom headers.
Freshly built TH400
-New Trans Cooler and Torque Converter
17' Vison Wheels on 42' Cut Sticky Treps
14 bolt front with RCV's
-Wilwood Disc Brakes
-Super 8 Aluminum Hubs
-New Seals and Oil as well.
14 Bolt Rear
.250 wall driveshafts with 1410 U-Joints
16' FOA Shocks all the way around
2.0 Fox Bump Stops
Dual Ram PSC steering Ram
205 Transfer case with fresh seal kit
Limit straps all the way around
Corbeau suspension seats
5 point harnesses
Optima Gel Battery
Quick connect steering wheel
LED Light Bar
Aluminum Four Link with 1.25 Heims
Aluminum Fuel Cell holds around 8 Gallons
Gated Shifter
Dual Fans on Radiator
Corvette style fuel pump
All new plugs, wires, fuel pump, and filters
Quick Connect Fire Extinguisher
All AN Fittings and braided hose
-Also have syntrifical Super Charger that is for this motor that can throw in for the right price. Has everything needed to install it, just never got around to it. Charger was just gone through and rebuilt, has 0 run time on it. Has intake piping, blow off valve, oil catch can, mounts, oil line, everything is there and will throw it in for a little more money.
I know I'm forgetting some more stuff. Great build, buggy performs well and is tough. Most of the parts have been put on in the past year. With very little run time on them. Can get more pictures on request or anything else you're needing. Buggy sounds amazing. Looking to sell for $30,000 with the super charger, or $29,000 without. Only trades would be for a 4wd tractor plus cash. Call, text, 606-356-6649
I've got a tractor out in the field. Ain't been started in 3-4 years but last time she started ran like a top. Prolly throw in 2-3k boot but that's it man.
