CCOR
706-559-9609
One of our driver's in the SRRS and Bounty Hill competitors is Travis "The Hitman" Lovett. He came to us about building a set of bullet proof axles for his Point And Shoot Hill Killer! The owner of CCOR Matthew Grimes took this as a challenge and accepted!
Requirements:
Can live with 700hp +, 44" cut Boggers, and be beaten by a rock bouncer!
Also needed to have extremely fast turning response for those crazy fast climbs!
He decided to build a set of 2.5 ton Rockwells! Front steer only to eliminate any weak points and keep it simple.
Here is what we started with!
These would have to hold up to some 44" cut boggers and custom 16.5 Double beadlocks from Trail Worthy Fab.
The first step was to tear down the axles and inspect them.
The first thing we discovered was the previous owner had installed a set of Mohawk pans but the welds were lacking a bit so we went over them again inside and out.
We also discovered that they had put the same side steering knuckle on both sides so a quick call to Red Barn Customs and we had another knuckle on the way with some spindle seals and studs too!
When your talking about bullet proof axles and rockwell's then there is one place to call, Overson Engineering.
The UPS guy thought we were shipping billets of lead when he dropped off all of the packages.
Violator Chromoly U-Joints
47 Spline 2" dia Chromoly Overson Shafts
Requirements:
