Sold/Expired Shop clean out
jmf
$1,200 gm 350. 280h comp cam. Scorpion rockers. Edlebrock intake and edlebrock aluminum heads.
$200 ea 42x15x15 on allied 8x6.5. Only two are for sale. Your choice. Keeping one and other is ripped. Someone can have that one for free. They all hold air but leak down over time.
$50 1 set 35/30 spline gm dana 60
$25 30 spline dana 60 lock outs
$150 1 set 35/35 spline gm dana 60
$75 1 short side 35/35 spline gm dana 60
$75 ea GM dana 60 knuckles. One has studs. One does not.
$50 set high steer arms
$10 gm dana 60 cover
$100 Holley truck avenger carb
$10 6 blade flex fan
$20 Woodward notcher. Needs new wear sleave and bit is welded to shaft.
$20 heat sink cooler
$5 15" electric fan
$5 Chinese 1/2 impact
$100 aluminum fuel tank 24x20x10. Foam filled. Don't know if sender works.
$5 ea yokes
1310 10 spline
1310 29 spline
1350 29 spline
1350 10 spline slip
1350 16 spline slip
$10 pro comp fuel gauge
Located in nw tn. 731-676-8729
Pics
More
Cooler measures 13". Outside to outside of mounting flange is 14.5"
Would you be able to send me pictures of the Wilwood MC's to 908-963-9013. Thanks.
