sommertime
- Joined
- Jan 9, 2009
- Messages
- 250
Re: ULTRA4 Chassis/Roller
Okay the car is 100% ready for a new owner.
Some things that where not listed on the previous post that will be included are.
-Window nets
-Mirrors
-ARB compressor and wiring (did not unhook the wiring for this)
-Left the wiring for the remote winch switch in dash
-Leaving the complete brake system including the line lock (for parking brake) and the master cylinders and custom built brake pedal and all plumbing
-Gas pedal and brand new lokar throttle cable (still in plastic)
-LS2 ceramic coated gasketless headers and complete exhaust (wrapped and ceramic coated)
-LS motor mounts
-Fuel filler and cap
-tri strap for spare tire
-complete ARB plumbing is staying
-Front PAC sway bar custom built for the car (this was not a cheap part obviously)
Things we noticed that need to be addressed upon reassembly
-Needs weld washers on the rear shock mounts welded in
-carrier bearing needs bearings possibly more
-needs a small amount of welding on motor mount gussets (these where added after assembly and just couldnt get welded with engine installed)
I also will have a KEVKO oil pan and remote oil filter available once I get a new pan ordered
I would also let the tires and wheels go with the chassis. (5) Krawlers on Trail Gear wheels with Tireballs installed.
If anyone has any questions please text or call
Chris
TWO14-728-Five773
-Window nets
-Mirrors
-LS motor mounts
Chris
TWO14-728-Five773
