This is an Eaton brand Char-Lynn Hydraulic Steering Valve. The model # on the side is 201-1021-005. Call or text 931-3O8-7746. Located in Cowan, TN. Asking $200 local pickup or will ship for $225. I will include the 4 straight o-ring fittings to adapt it to AN6 hose fittings.
7.3 cubic inch displacement (3.4 turns lock to lock with a 2" bore 8" stroke cylinder)
Open center oil flow
Non-load reaction cylinder circuit
9/16"-18 oring ports (fiitngs included)
2500 psi maximum pressure rating
3 GPM nominal oil flow rating, 2-4 GPM range
Manual steering check valve
