Sold/Expired SOLD Poison Spyder Bruiser,6.0L LQ4, Atlas,D60,Corp 14, 43x14.5x17 SXII
dacotah
Sold
For Sale - Poison Spider Chassis - 6.0L Buggy
Location: Grand Forks, North Dakota – Contact Lon 701-741-0513
Price: $23,000 (will consider two seat moon buggy trade or small rock crawler, will also consider trades of TJ, LJ, JK, JKU, Polaris XP 1000
$20,000 without tires and rims - you supply your own
Will drive halfway in the lower 48 to deliver.
[email protected]
More images at the following link:
https://goo.gl/photos/pQYx75UUxe8KFeJk9
110" wheelbase Poison Spider Chassis
Chevrolet 6.0 V8, engine cammed to approximately 400HP, ecm and harness by Schwanke, Kevko oil pan with baffles, K&N air filter, remote mounted oil filter, Dual exhaust with mufflers
TH350 TCI transmission with reverse manual valve body, with 10" 2500 stall converter and Art Carr shifter, Derale transmission cooler with fan
Front axle – GM D60, 5.13 gear ratio, Detroit locker, full 35 spline chromoly axles with Yukon Super Joints, full 4 link suspension with all 1.25" heims, Blue Torch Fab truss, diff cover and pinion guard, PSC full hydraulic steering with double end ram, 8" Derale fan driven cooler and full disc brakes
Rear axle – GM full float Corp 14 bolt, 5.13 gear ratio, with Detroit locker, full 4 link suspension with all 1.25" heims, Blue Torch Fab truss, diff cover and pinion guard and full disc brakes, rear Currie Anti-rock sway bar
CBR double pass rear mounted radiator, 27"x19", with two fully shrouded 12" fans, rear mount with braided lines and AN fittings
14 x 2.0 King Coilovers front and rear
Atlas 5.0 transfercase with Atlas cable control linkage
Interco Super Swamper TSL/SX 43x14.5x17 SXII tires on 17" Raceline aluminum beadlocks
Warn 9.5TI Winch, 100" synthetic rope, hand remote and cab mounted control
Moroso Performance Rocker Switch Panel with breakers, Portable air compressor and fire extinguisher installed in cab, Quick release steering wheel, Autometer Gauges - Tachometer, Oil pressure, Water temperature, Transmission temperature, Voltage, 16 Gallon fuel cell, Corvette style brake master cylinder with booster, all steel braided brake lines with AN fittings, high back 5 point black vinyl buckets seat and 4 point seat harnesses
gjgxMtLfaXYKbJ0r4icxnT5T-t8aGDOg7p3vjXRhzfU=w1006-h605-no
PqPPULWf__3SKoOZfAo3gBUEhHUmi2na0jbnIQ_RjqE=w541-h960-no
Re: Poison Spyder Bruiser, 6.0L LQ4, Atlas, D60, Corp 14, 43x14.5x17 SXII on beadloc
Sorry link above was incorrect. It has been changed.
Re: Poison Spyder Bruiser,6.0L LQ4, Atlas,D60,Corp 14, 43x14.5x17 SXII on beadlocks
I will drive halfway in the lower 48 to deliver.
tt
Sick rig !!!! bump for ya.
btt
New price option.
Could use 90% or better 40"x17" tires, with or without beadlocks, as partial trade.
btt
btt
Can a tall person fit?
Yes, I think up to 6'3" should be OK.
could use Polaris XP 1000
btt
Sold
