Rjhoward32006
Feeler to see if anyone is interested in a set of built axles or if anyone is interested in enough parts to part them out. Located in taylorsville georgia work in atlanta.
678-451-2794 [email protected] f
For the right price i have spare everything from housing'd to thirds, knuckles,shafts
Add up all the parts and there is over 4k in parts. Because i have to add a price 2k obo
Or trade for a set of mild d60's pass drop front.
85 front and rear housings with long bottom truss.
4 linked front and rear. Dual triangulation 7/8" heims
Front has air bump landing pads.
Set-up for coilovers
Front axle
Rcv's
4:88 and spool (one ride)
Diff stud delete upgraded to internall stifining ring with 3/8" bolts
Double ended steering ram 6"
Aluminum tie rods
3/4 heims and safety misalignments
6 shooter knuckles
Trunion bearing eliminators
New bearings and seals. Have extra set of wiper seals
Rcv drive flanges modded to 12 bolts 3/8" fine thread grade 8
2" wheel spacers
Btf full diff protection.
Ram mount is 3/8" plate
Center limit strap mount
2x3 truss up top for 4 link and ram mount
Stock 4 piston calipers and rotors
Trail-gear hd inner axle seals
Rear is 85 narrow
Yukon chromos
4:88 welded diff (three rides)
Stud eleminated and internal stifener ring with 3/8" bolts
Chevy 3/4 ton single piston calipers and brackets
2" wheel spacers
Center limit strap
2x3 truss
Btf diff cover
Front axle
Rcv's
Aluminum tie rods
6 shooter knuckles
2" wheel spacers
Rear is 85 narrow
Yukon chromos
2" wheel spacers
Center limit strap
2x3 truss
Btf diff cover
