Spidertrax axle brakes to fit a 15" wheel
Redneckryder549
Active Member
Does anyone know which rotor, caliper etc to use on a front and rear spidertrax 9" with pro knuckles and unit bearings to be able to run a 15" wheel with positive backs spacing?
Waffle, are those stock SRW hubs? If so, which studs are those? I have the same rotors but different brackets that put the rotor behind the hub. I'd like them to slide over the front of the hub like yours so I can use longer wheel studs. How do you get to the calipers bolts if they go inside the bracket like that?
Here's what I have now.
