Steel Beadlock Question
L
lowbudgetjunk
Guest
I have a well worn set of Beadlocks I bought from Adam Lee. As my name suggests, I want to come up with a solution that is cheap to put these Beadlocks back onto the trail. He drilled out one of the valve stems and put in a tube. I searched here and pirate and found a guy that put an npt fitting for quick air down, and redrilled and tapped for a valve stem. I did not see anything for repairing a larger hole.
My newb question is, after I replace my piece of metal and weld it in, what should I do to ensure it doesn't leak down from the new piece of metal? I am not worried about it balancing due to it being 100% offroad only and never over twenty miles an hour.
bad80cj said:
Bring it to me ;) I will weld it up and make it right. No problem :****:
Want to mount some tires while you are at it? I'm running out of small projects on the Jeep and I'm running out of excuses as to why it's still in the garage :)
zukimaster said:
After you weld it up, dab some silicone around it just for good measure!
That is part of what I was worried about being steel. Rust and time. I figured I would paint then silicone, just didn't know the best method
If you weld a square piece of thin plate on the inside then fill the hole with weld then grind smooth it shouldn't leak! Or even be noticeable
This is what I did to mine when I moved my valve stems toward the center of the wheel. I didn't bother grinding them since they are fugly anyways.
Swing by a tire store, big rigs, and tractors have bigger valve stems, might be able to score some and drill your hole to match
Had the same issue, happened to be a professional afro engineering, I used black RTV, "The Right Stuff" screwed my valve stem on, never had any issues at all. This was something that had to be done asap while wheeling, and just kind of forgot about it. It worked for me anyways. Just a dark idea. :afro:
bought a set of wheels a while back and put myself in that same position.
The valve stem holes were drilled to 5/8" for tubes. I got valve stems from a tractor trailer tire shop, popped them in and they never leaked a bit
I may see if Ryan wants any part of them. I just like the idea of a second fitting to quickly drop the air pressure without having to mess with the valve stem core. I think if the hole is welded up and two new holes are drilled, that is going to be the best option.
