swing-away tire carrier hinges
blackrubi1
Active Member
Lakeland hills
I am making my own swing-away tire carrier. Thinking of using a A to Z fabrication hinge. Has anyone used this? Any advice or tips on this project?
Hub and spindle from a trailer work good for cheap :awesomework:
i welded an old 9 inch axel thru the bumper and made brass bushings for it to fit inside some 2" tube.
ive seen many a fabrication hinge bend...
I don't know how much weight you're looking to support, but I have the stock swing-out tire carrier (and latch) from an S10 Blazer that I would sell for pretty cheap. You could then modify it to fit your needs. But like I said, I'm not sure how much weight the hinges on it would support. PM me if you're interested.
I noticed that the welding store out by me has some universal type weld on hinge things similar to other ones Ive seen online (not like the Rockstomper ones). I have no idea how they would hold up, but just throwing it out there.
~T.J.
~T.J.
bent before i even mounted the tire on the carrier.
I just had this happen yesterday and thought that I would post it up.
On the way home from running an errand the axle stub that I used for my hingle sheered and the tire carrier along with everything else swung out via the latch then came to a rest in the oncoming lane of traffic. Luckily there was no one around and I was able to pull over and drag the whole thing to the side of the road before someone came along.
The axle stub was 1-1\16" thick where it broke, right were the bearing rode on the axle stub. I am not sure if it was already flawed or there was an early crack that finally broke as a result of the cyclic movement of the tire carrier. Regardless I am going to be using a double sheer design for the next version and attach a chain on the hinge side of the tire carrier to both stop the tire carrier when it swings out and as a saftey feature so that if this should ever happen again it will be attached some how to the vehicle and give me some time to pull over preventing an accident.
Just for the record the tire carrier was built about 3 or 4 years ago. I think that I can bend the Hi Lift back on a using a press, or at least I hope so.
