toyota 1350 yoke?
alscott
Lenoir City TN
Im looking for 1350 yokes to go on my toy t-case. I have found the bolt on J E reel ones but does anybody else make one that replaces the old toy yoke instead of a bolt on?
thanks
im making the move to 14 bolts and want to keep the same joint at the axle and case is my reason for wanting this. Ive got a bobby long output shaft so im not real worried bout it. If it does break then ill buy one from rcv
Call Murel at Athens Driveline if they make it they have it or can get it.
423-745-6954 :****:
Neal3000 said:
Whats so bad about the JTReel bolt on 1350 flange?
High jack on ( Where in the Sam HELL do you find the pictures for your avid)
High jack off :dblthumb:
alscott said:
Problem is my driveshafts are on their last leg now, the splines are same as wore out.
I still like the yoga shafts. Should be able to find them for cheap all day long. I think I got an old front shaft you can have and use the slip off it. PM me if you want it and I can meet you.
